Hi Everyone!
Curious if anyone has created a way to expand a single cell with an “In Row Button”.
Hopefully the gif helps explain what I’m attempting to do!
Hey @Scott_Hill ,
See this topic (my original post and the follow-up corrections):
P.S. Apologies, I thought you wanted to show a row popup, not a column popup.
To programmatically open a cell in Big Text editor, do pretty much the same (OpenWindow() with a constructed URL), but the URL should have a columnId parameter in it, e.g.:
OpenWindow(Format(
"#_tuVES/r{1}&columnId=c-PntQl8r7ye&modal=true",
thisRow.RowId()
To get column ID, enable Developer Mode in your account settings in the bottom under Labs. Then you’ll see an option to copy Column ID in your column context menu:
Alternatively just open the popup manually and inspect your browser’s URL:
Thanks @Paul_Danyliuk ! I didn’t know that this was a thing at all! Trying to implement this right now but keep running into the same issue where it seems like the URL is not constructed properly. Any ideas?
Whoops, a typo there, the URL should start with # so that only the “hash” part of the URL is replaced.
Overall the URL anatomy is:
https://coda.io/d/{IRRELEVANT_DOC_NAME}_d{DOC_ID_10_CHARS}
/{IRRELEVANT_PAGE_NAME}_su{PAGE_ID_3_CHARS}
#{IRRELEVANT_TABLE_OR_VIEW_NAME}_tu{OBJECT_ID_3_CHARS}
/r{ROW_ID} --- or --- /rui-{ROW_UID_10_CHARS} (optional)
&columnId=c-{COL_ID_10_CHARS} (optional)
&modal=true (optional)
— and following relative URL rules you can omit everything before #, or if you need to link to a page you can just keep the /_su{PAGE_ID}
