Please explain the primary difference between ValueTypes (fairly straightforard) and ValueHintTypes. I don’t understand the definition below.
Enumeration: ValueHintType
Synthetic types that instruct Coda how to coerce values from primitives at ingestion time.
Ouch, that language is hard to read! Our reference documentation needs a lot more polish, but this page in the guides is a bit more approachable:
To indicate that Coda should display your value in a more meaningful way you can set a value hint. The enumeration ValueHintType defines the set of supported value hints, which correspond to the column formats in Coda.
This table that shows the mapping between Coda column types and ValueType + ValueHintType might also help clear it up? Let me know if you have any follow-up questions.
Thank you Eric. That helps!
One more question related to the sunrise - sunset pack:
What does context mean in this line of code?
execute: async function ([lat, lng, date], context) {
Context is kind of a magic thing that you can mostly ignore (but you have to include it). Basically it gives you access to things like the API authentication you’ve configured, the built-in fetching function for hitting API endpoints, etc.
For example, when reaching out to an API, you write something like:
method: "GET",
url: url,
You’re able to write “context.” because you’ve included “context” up in that execute line.
That’s mostly all you need to know but to take it one step further, I often create a totally separate function to handle my executes, and I pass context along the chain. So I have something like:
return getDaylight(lat, lng, date, context);
and then elsewhere I define how that function works:
export async function getDaylight(lat, lng, date, context) {
method: "GET",
url: url,
// do complex stuff that was too big & ugly for my taste to include
// in the formula definition - in fact this is usually stuffed in some
// some other file (I use the command-line approach which allows
// for multiple files)
Oh I see Eric answered in your other thread
It’s a great answer though @Nick_HE ! I just realized my user settings were set such that I wasn’t getting notified of replies, whoops! Should be fixed now.
