Hello community,
I had been looking for a way to create a variable set of buttons for a “workflow” application that continues to grow in processes.
Right now, it is easy to create a set of variable button inside of a table, but not have them display horizontally, as if you reference the set of buttons, you end up with this:
However, with a little tweak and by using the FormulaMap and Button formulas, you can have them display as a neat list in your application:
Hope that helps you if you run across a similar (but niche) use case, thanks!
