hi from turkey, I tried to generate vcard QRCODE image, but too sophisticated for me ( I think). Anybody succeeded? or Tried (maybe know-how share?)
coda supports qrcode generation but just as url. I need vcard
Thank you all
Thank you all
Hi @anon42070253,
Welcome to the Coda Community!
I created an example that should work. This is simply a matter of creating the proper text for the QR code to include. I found this article that shows the layout of a QR Code: VCards in email signatures
Then I created a table with all the relevant columns I needed. I then added a formula to compile all the values into the proper vCard text format using the Concatenate() formula. Then the QR Code column just reads from this “vCard Text” column.
Here’s a working example:
Thank you @Ben_Lee.
I was close but cant achive , was drowning in concatenate quotes
Hi @Ben_Lee, The issue I am facing is how to include this QR code to an email sent via Gmail pack and make it visible. It doesn’t seem to work.
