I like the approach @Max_OBrien , I would have never thought about using the Rectangle function to visualize trends, thx for sharing!
So cool @Max_OBrien, thanks for sharing !
Rectangle() is one of my favorite functions
In the same idea, I’ve used it to quickly show workload of a team, including weeends
Or even improved Gantt Chart with % of Progress
And good old daily habits !
But using it as kind of chart is really interesting ! thanks
HOW IT WORKS
you start with a List() of values you want to show as a Sparkline.
the values should be be between 1 and 15. dont use zero, 1 is the smallest.
so you may need a formula to convert the original data into this range.
eg. for a set of percentages that formula would be
Percentages.Foreach(Currentvalue*14+1) // 0.00…1.00 → 1…15
so for a monochrome Sparkline (in green) using a list of values called Values you use this formula
Values.Foreach(Rectangle(5,CurrentValue,"#00FF00").Concatenate()
but if you want to have a multicolored Sparkline,
then you need 2 lists of values; one for the numbers and the other for the color of each bar
lets say those lists are DataItems and BarColors
where the colors are strings in the form “#RRGGBB” for red(RR) green(GG) and blue(BB) hex values
thus the formula for the colored Sparkline would then be
Sequence(1,Count(DataItems)) // need an index for each pair
.Foreach(CurrentValue.Withname(N // call the index N N=1..list size
Rectangle(5 // draw a rectangle of with 5 pixels
DataItems.Nth(N), // height of the nth item
BarColors.Nth(N) // using the nth color from the list
.Concatenate() // and concatenate them all into a single row
i have a senior VP client who is fond of saying
“never mind the numbers, show me the SPARKLES !”
Max, as someone who works with financial data a lot, this solution is amazing!
Quentin, You and @Max_OBrien are opening up so many possibilities for how to incorporate Edward Tufte’s “Envisioning Information” frameworks into my docs. Thank you!
Love this visualization, @Max_OBrien! Immediately made me think of @Quentin_Morel’s inspired solution to display workload in a similar manner, but while I was still searching for the original post, he beat me to it ![]()
Fully echoing @adoc_mama’s sentiment, you both contribute a new way of incorporating visualizations within Coda doc, thanks so much for sharing!
Love that you can showcase increase, decrease and no change with different colors Max, I am always surprised by your creativity ![]()
Just want to share how the same looks with the Sparkline Pack, depending on the use case it may be a better option:
