What's wrong with Coda's horizontal navigation?
The mobile app at Coda is a separate story. It seems to have been created just to tick a box. It is simply impossible to use properly. It is mainly used for notifications.
Without mobile usage Coda would make sense for at most 10% of my business cases, so I try (really hard) to keep utilise Coda app for whatever possible. It’s not unusable, but there are few points that make it hard to like. The space-wasting UI is definitely one of them.
I also like the quickness of the Notion’s horizontal tabs. in Coda I’m using the filter bar and it’s 3 clicks to change: (1) click to open the filter (2) uncheck the current filter A (3) check the new filter B. all those clicks add up to a tedious experience for me
+1 again for horizontal navigation and tab
Just wanted to share an update that tabbed views, a new horizontal navigation pattern for data, are now available! This new feature allows you to organize multiple views as tabs in one component and navigate through them with a click. Open any table and click the + by the table title to try it.
Read the full announcement here.
