# "X" is not a valid row reference for filtered crossdoc table
**URL:** <https://connect.superhuman.com/t/x-is-not-a-valid-row-reference-for-filtered-crossdoc-table/20610>\
**Created:** [January 7, 2021, 5:22pm UTC](https://connect.superhuman.com/t/x-is-not-a-valid-row-reference-for-filtered-crossdoc-table/20610 "2021-01-07T17:22:49Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Johg\_Ananda](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/johg_ananda/32/13930_2.png) [@Johg\_Ananda](https://connect.superhuman.com/u/Johg_Ananda)\
**Post date:** [January 7, 2021, 5:22pm UTC](https://connect.superhuman.com/t/x-is-not-a-valid-row-reference-for-filtered-crossdoc-table/20610/1 "2021-01-07T17:22:49Z")
</div>
I have a doc that is CrossDoc’ing in two tables, `A` & `R`. Table `R` has a column `RA` that is a multi-select lookup-type column of `A`.
`A` is a large table, and `R` only requires 30% of the rows, so due to size considerations I CDoc in a filtered view of A, `AThird`.
The problem is that Coda does not recognize `AThird` as the ‘original’ table `A` that `R` references, so this provides the ‘Not a Valid Row Reference’.
When there is a single value in `RA`, I can ‘hack’ the problem with
`AThird.filter(A=thisRow.Row.R.ToText())`
The problem is when there are multiple values in `RA`. I have tried to use `ToText()` with `ParseCSV()` to generate a list of values in `RA` and then find them with `Contains()`. I can’t get this to work.
Any ideas on how to adjust my schema, lookups or formula to get the values to match?
