Abbreviated Month Names
I feel like this is so simple but somehow I can’t figure it out…
I have one column with a date value, and a second column, which is a text formula, that I want to display as “21-01-Jan” etc, based on the date in that first column.
So I’m going for 2-digit year + 2-digit month number + 3-character month name.
I’ve tried using the format function, and this bit from the MonthName formula
…but I’m not sure how to actually use this in the formula. :confused: Is it this?
Format(“{MMM}”,[Date].MonthName())
…because that’s literally returning 2021-01-{MMM}.
I’ve tried a bunch of things but the only thing that’s worked so far is the Month Number bit. The rest I’m lost on. Here’s where I am currently, which displays as 2021-01-January:
Concatenate([Date].Year(),“-”,Format(“{1:00}”,[Date].Month()),“-”,[Date].MonthName())
Grateful for your brains on this little silly thing!
Hi @Kelly_Claus :blush: !
Actually, the “MMM” or “MMMM” you can use in MonthName() is the 2nd and optional parameter you can place within the brackets of MonthName(), after the mandatory DateTime :blush: .
MonthName(dateTime, format)
E.g. : something like…
MonthName(Date(2021,11,29), "MMM")
… will return → Nov
or
MonthName(Date(2021,11,29), "MMMM")
… will return → November :blush: .
If you “chain” it you could have something like :
Date(2021,11,29).MonthName("MMM")
it would also return → Nov
The format in the documentation concerning this formula, is the format to use for this parameter in MonthName(). (and has nothing to do with Format() :blush: )
Now, concerning the specific formatting you want to use maybe this could help you :
Format(
  "{1}-{2:00}-{3}",
  thisRow.Date.Year().Right(2),
  thisRow.Date.Month(),
  thisRow.Date.MonthName("MMM")
Here is a quick simple, just to illustrate :blush:
Amazing, thank you!!
No problem @Kelly_Claus :grin: !
