Ability to Print Timeline view as you see it
I’ve asked for this for ages - when you go to print a timeline view the print defaults to Quarterly view, even if the timeline is set on monthly or weekly, etc. view, and there is no way to change it. This is an issue and degrades the ability to use the timeline view to, for instance, print off for a client to view. The Quarterly view squishes all the data to the left and it looks terrible. Please fix this!
any updates here? or a workaround?
I have a doc here and clients need to see the timeline view. Do I really have to printscreen? (Looks very unprofessional)
Hard agree on this request. We want to start using Coda for all project schedule sharing, but the ability to export as PDF is a non-negotiable for us. Need to be able to print timelines in Month view.
no updates? i also need PDF Export function
As soon as I got access to Coda MCP, I started sharing timelines as images generated by Nano Banana. Example…
There are several aspects to using Coda MCP for this, and Nano Banana is only one of the visualization options. I have also experimented with extracting the data via MCP and generating HTML with precision and converting to PDF.
