Access Pack Settings in Coda Formulas?
Is it possible to configure a field in the pack sync settings that can then be used in a Coda formula?
I am referring to these settings in the Coda front end - can I add an item here whose value then becomes accessible to Coda formulas?
You can’t do that directly.
What you can do, though, is create a named control in your canvas (eg.: a text field to hold the URL value) and use that both as value to your pack settings as well as using it on formulas.
So you can have what you want, just no the way you thought in the first place.
Does that answer your question?
