jeo
April 26, 2020, 4:59pm
1
https://connect.superhuman.com/t/realistic-number-of-rows-in-a-table/5916/18
Coda API and cross-doc stops working when the doc’s JSON goes over 125 MB limit. You can see the limit in developer tools — that would be the largest file loading. Usually it’s much smaller though in compressed state — 125 MB is the limit of uncompressed one.
Got this info from Coda support. That said, the doc would still load in UI even if it’s over that limit.
Codans, can you please consider adding a location where the document size (MB) can be reviewed?
Part of being a good steward of digital resources is being able to monitor how quickly day to day usage is moving towards a limit … even if future performance optimization decreases the doc size or increases the capacity
example)
Bump - this topic grows more important every day as more people use Coda and their docs grow. This would be a stop-gap until the limit is increased.
Yes please - as it stands there doesn’t appear to be any warning before hitting the limit, the API just dies
