Hi there!
In the Coda Template, “Content Library,” there is the ability to toggle based, on and off “View all content, including completed.”
How can I add this ability to my other tables with columns with checked boxes?
Hi there!
Welcome to our community.
Here is a simple way.
Just have this very simple layout, and add the toggle.
What you want is filtering your table according to the status of the toggle.
I would use a simple formula like this in the table filter.
Please let me know if I well understood your point (I did not open the template you mentionned)
d
Cheers.
Quentin
This fix worked!
Small caveat is that when I was writing the formula, the “show_completed” or toggle attribute didn’t appear, initially.
