Adding columns to multiple tables
Hi there,
Since views of tables is a much-used feature, it would be great to have an option when a new row is added to a view or table, to add it as visible to all the others at the same time.
Thanks.
Do you mean column?
If yes, it should not standaard add them (visible) to all other views: those views are usually filled with carefully selected columns.
Yes, sorry; I meant column.
And not standard but you should be able to choose where to add them from a pop-up perhaps, rather than have to visit each view, unhide, and them move them to the right place.
