Address auto-completion in forms
Hello,
I have a form with an address field. I am wondering if there is a solution to achieve address auto-completion, similar to how Google Maps has a dropdown that appears when a few characters are typed in. If that is not possible, what would you recommend as a best practice pattern to input a custom address in a form ?
Thanks,
Unfortunately that can’t be done in a Coda form at this time.
You’d need to use a third party form and pipe it’s data into Coda for that.
Alternatively, you can use the Smarty Street pack to validate addresses after an address is submitted to Coda, but it requires that you have an Smarty street account.
