I want to important just one table. Can I not do that? It is apart of a larger base.
Hello @Ashley_Shuler! We intentionally designed the importer in such a way that you cannot import an Airtable table without its linked tables. This is to prevent references from being broken once the table is imported into Coda. To import a single table you can either:
- Remove the reference columns in Airtable, then import the single table.
- Import all linked tables into Coda and just delete the other tables you don’t need. Be aware that references will be broken when this happens.
Let us know if you have any other questions!
Thank you @Sam_Sloate ! I appreciate it. I will try and see!
