Okay, we made a form on our code that has varying name lengths per field and this is what it looks like:
Can we please have the input fields align? That would really help the visuals.
Indeed. And, sadly, we’re still using forms. We should transition to a no-forms society. The data required for every form can be obtained through simple conversations, and more than a third of it can be inferred.
What are you talking about?
We organize a yearly multi day event and this is how people register for artist or dealer spots…
Very weird comment not gonna lie.
I should have explained myself better. This might be less weird.
The “Form” is a relic of the database era—a rigid interface that forces humans to think like machines. We ask users to navigate dropdowns, format dates (ISO-8601), and decipher validation errors, effectively offloading the database’s strict schema requirements onto the user’s cognitive load by slicing up their information into pre-parsed chunks.
Research into Formative and Action-Oriented Agents suggests a superior alternative: The Agentic Interview.
Don’t Ask Users to Fill Blanks. Ask Them to Tell Their Story.
Instead of exposing the raw database schema (the Form) to the user, we should use it as a hidden script for an intelligent agent. The agent, possessing the “Schema Defense” capabilities of Coda mcpOS™, acts as a universal adapter between human fluidity and database rigidity.
Forms are dumb. They don’t know who you are or what you did five minutes ago.
Nothing kills flow like a red error message: “Invalid Date Format. Please use YYYY-MM-DD.”
"2025-10-14" before the database ever sees it. The user never sees a validation error because the agent fixes the data in flight.Forms are static; reality is not. A complex “Incident Report” form might have 50 fields, 40 of which are irrelevant to a minor issue. We try to intelligently maneuver around irrelevance through mechanicly-driven conditions, but we generally fail.
We do not discard the Form’s structure; we discard its interface.
table_add_rows directly.Conclusion:
By replacing forms with Agentic Interviews, we shift from Data Entry (a servant to the machine) to Knowledge Capture (a conversation with a colleague or customer). Validated, structured data remains the outcome, but the human cost of acquiring it drops to near zero in the best cases and to substantially less in the worst cases.
Haha that makes it less weird indeed. Well for now a simple form still works would just be nice if the fields aligned ![]()
It doesn’t make it any less problematic for sure.
Here’s an idea: what if you used Google AI Studio (it’s free) and gave it your form, or even the URL to your form, because it can read anything on the web?
You could ask it to build a better form that you can publish and describe how you want it formatted so that it’s elegant and clean. I have a hunch that the AI will basically build you an app that functions as that form. I would give it a try.
Could check that out but our main information and registration source is Coda soci rather stay within it!
Yeah, I get that. I’m suggesting you build a form proxy using AI that injects the data into Coda. There’s a simple pathway to do that using Coda hooks. They’re very easy to establish, allowing you to write straight into your data from any kind of form (it doesn’t even have to be a Coda form).
Here is the process you can follow:
Once you have that done, any application can write into your Coda data table. This allows you to create very powerful form proxies—essentially custom apps that serve whatever need you have—100% by describing the app that you need.
If you have a table that you can expose to me, I’ll walk you through it. I’ll even tell Google AI Studio to build a sample app.
Here’s a workaround:
You can try to insert “invisible” characters to the description fields that doesn’t align to force them to move downwards.
One character is enough to match fields that are 1 line downwards, for multiple lines I think you need to add multiple invisible characters until you force the description to span over 2 or more rows
