I did the usual search site:https://connect.superhuman.com/ anonymous publish to check for relevant previous content, and I got about 8 results. Nothing really relevant so here goes.
I just published my first public doc. I went to check “what can people find about the author”.
I’d like to suggest an “anonymity” toggle option for public publishing and perhaps that is even a good going forward default? Whereby no published bytes for the doc leak details about the author.
This would address the usual privacy concerns about unwanted contact and/or doxxing.
I was able to simply use my browsers view-source: mode to see and search for author details in the published doc. This was not desired for this particular case and likely the majority of my use cases.
