Hi all,
One nice way to jazz up the look of a doc is images, it’d be cool if there was a way for Coda to search the web for an image based on the contents of a cell and put it straight in.
Anyone have any clever ideas how that could be done?
Hi all,
I’ve done something like before using the Wikipedia pack.
Here I turned dog names into Wikipedia pages and got the images. I had to manually over ride some to make it work. Looks like I need to go back and update some.
Clever! Hadn’t used that pack before.
A pack for Google Search (or alternative) would be pretty clever, especially if it could search image instead and pull results in and you can pick from a few options.
Agreed, that’s what I wanted when I ended up using this method. Hopefully something we’ll get to in the future as a pack
Hey @Josh_Unwin1 , if you 're still looking for a solution to this, I just released a Google Image Search Pack for Coda that automatically returns the first Google image based on the contents of a cell (and several optional parameters like size, color, nsfw, etc.). Check it out and let me know what you think!
