Any way to clear selection control component with a button
I want to clear the selection of a select control component with a button.
Is this possible?
I have selected 3 items, which is filtered from a table. These three items updates another table, and I do acitons on them.
But when Im done with the 3 items and want to clear out, how can I do this with a button?
What do you mean by a “Select control component” ?
Do you just wish to clear what you selected with your select list ?
I want to clear this select control component
It is a component made by coda, and added through + -> Controll -> Select/Multiple select
Hence the name.
How can I clear this with a button/formula/automation?
I sadly think this is not doable with a control on the canva :confused: .
But what you could do, is create a mini table with a multi-select list and a button Clear like this :
Thanks for that clarification and help.
It lead me to a solution that works. Just hide everything around
But it is really strange that we dont have actions on these control components though🤔
#featurerequest
I agree, this is annoying - some of my tables have controls with 50 different selection options - can I not just unselect all? At the moment I have to individually deselect each one, it’s annoying
Today there is!
