Is there a way to add text snippets like if i type /login i can use a long text that I had saved in login snippet? I seem to need to some lines of text everywhere and want to minimize the process.
Thank you in advance.
Hi Ujwal,
Here are two ways in which you can do something like you are looking for:
Option one is going to be quicker to use, but it is not going to inline replace your text. Option two is longer, so will work better with sentences and even paragraphs.
Let’s see if other community members have other ideas.
Regards
Piet
