My use case : a get request. I added to a pack schema and a sync table.
But I have a problem with the schema sync with this type of response :
{“things”:[{“thing”:{“id”:1,“name”:“super name”}},{“thing”:{“id”:2,“name”:“super name 2”}}]}
I don’t understand how I have to write the different schemas…
Hi @Virginie_Beurton_Le_Mignon - Welcome to the Coda community! Schema design is certainly a bit tricky at first. For a response like this, you could write code like this:
const ThingSchema = coda.makeObjectSchema({
properties: {
// Use fromKey to rename "id" to "thingId", as per the best practices.
thingId: { type: coda.ValueType.String, fromKey: "id" },
name: { type: coda.ValueType.String },
displayProperty: "name",
idProperty: "thingId",
pack.addSyncTable({
description: "",
identityName: "Thing",
schema: ThingSchema,
formula: {
description: "",
parameters: [],
execute: async function ([], context) {
// Pull out the outer list of "things".
let things = response.body.things;
let rows = [];
for (let item of things) {
// Reach into the inner "thing" and add it to the rows.
rows.push(item.thing);
return {
result: rows,
There’s a lot going on there, so let me know if you have follow-up questions.
