Auto highlight a date cell if it's older than a certain number of days
Hi there!
I am trying to troubleshoot an issue and was wondering if I could get some assistance!
I have a “Last Contacted” column in my CRM, and I am either hoping to:
  1. Have it highlight automatically (maybe with a specific color) if it’s older than a certain number of days. For example, if the last time I contacted them was more than 3 weeks ago, I want the cell to change color.
  2. OR (less preferable) have an alert send me an email if it’s older than certain number of days.
Is this possible?
YK
Hi @YK_Hong,
Welcome to the Coda Community!
You can add conditional formatting to highlight any column based on a particular criteria. Here’s a simple formula you can use for finding anything with a date before 7 days before today.
thisRow.Date < Today()-Days(7)
Thanks for the response. I might need to be walked through this one.
Am I going to Last Contacted (my row I’m trying to work with) > Conditional Format > Edit Format > Add formula > add the formula you gave > then apply to Last Contacted with set format to, say, Red highlight.
If I do that, nothing changes so I’m assuming I’m not doing this correctly.
Thanks in advance!
Where I have thisRow.Date in the formula, you might need to have thisRow.[Last Contacted] instead.
You rock. Thank you so much! That did it.
