Auto Populate from a Checkbox
Hey!
I’m looking into seeing if I can get this done on Coda and unsure if this is possible… so apologise if it’s not.
I’m using Coda to track different grants and income schemes. I’ve got a few different pages, each with a timeline on and tracking the start & end date of each of the grant.
I’m looking at doing 1 page overall that I can build a timeline on of all the grants and merge together all the different timelines/tables that I’ve built on other pages.
Question 1) Is this possible?
Question 2) I want this to only fill in that timeline/table if I have a checkbox ticked.
Fingers crossed this makes sense… I just can’t seem to find the answer for this!
Hey Tommy,
Welcome to the community!
Do I understand correctly that you have a table per grant in different pages? Unless you have a very good reason to keep them in separate tables, it would make sense to have only one table and create views filtered by grant.
You could add a checkbox and a timeline view, where only the checked items are displayed.
It would be easier to help you if you could share a dummy doc, but it sounds totally doable.
Hope this helps,
Pablo
