Hi Team,
I was thinking of writing an automation to loop over every row and every column and ‘TRIM()’ to remove trailing white space. This just keeps the system a little cleaner.
My best case scenario is something like a button that I click once a week that goes
- Loop over ‘Every Table in Doc’ and
- Loop over ‘Every Row in Table’ and
- For every column TRIM() any whitespace out.
Does anyone know a good way to do this?
Hi Logan,
You can create such a button, but you have to specify each table and column manually. It would be something like this:
RunActions(
Table_1.forEach(
currentValue.modifyRows(
Column_1, currentValue.Column_1.trim(),
Column_n, currentValue.Column_n.trim()
Table_n.forEach(
Let me know if this helps,
Pablo
Hi @Pablo_DV ,
Thank you for your suggestion. It works but unfortunately, this would be a long formula that would need constant updating.
I am definitely open to more suggestions!
A possible solution could exists if there was a coda formula like the excel Indirect() formula. This would enable us to use a variable as the name of a column or table.
E.g.
// Example only, this code does not work in coda
Withname(
List("Table 1, "Table 2", "Table 3"),
listOfTableNames,
listOfTableNames.ForEach(
// E.g. currentValue = "Table 1" as text
Indirect(currentValue).ForEach(
// E.g. currentValue = [Table 1] as table reference
currentValue.ForEach(
// E.g. currentValue = A row in the current table
currentValue.ModifyRows(
// Still not sure how to make it loop through each column programmatically.
If we had that, we could used a pack like this which generates a synctable of all tables in my doc and also get a syncable of all columns.
But enough dreaming for now. Anyone got any suggestions?
Hi Logan,
@Scott_Collier-Weir has a pack called Doc Explorer, and one of the things it does is to give you a list of the tables in your doc.
See if you cannot use forEach() to cycle through the entries in this table.
P
That would definetly open interesting possibilities! But I’m afraid there’s nothing like that at the moment.
I have not tested it, but I highly doubt that you can use the list of tables returned by Piet’s suggestion to iterate through all the rows of each table.
Also, for a given table, there’s no way to iterate through all the columns without specifying them, though some have already suggested it: New formulas for columns - Suggestion Box - Coda Maker Community
