Automatic Progress Bar based on Checkboxes
Hi!
I would like to have a progress bar column in a table that automatically updates based on the checked boxes in another table.
So, basically, I created this dummy example;
“Action Tracker Table” has the general action points i need to work on.
“Action Itemised” below is a lookup of the above but grouped and check boxes to be able to add individual action points. Once I keep checking the boxes the column “Progress” in the first table automatically updates to reflect a % progress (so, calculates based on the number of checkboxes each action has)
I hope I am making sense and very grateful if someone could help me!
Hi @Miguel_Gomez
  • Start to find the finished checkbox in action itemised for current action with this formula
  • The same for total check, without the conditionning for check is true
  • Progress bar will be Finished Check / Total Check, and enjoy !
CPT2211122156-1097x822
Is that what you wanted ?
Cheers,
Q.
That’s perfect!
Thanks so much!!!
Be my guest, I entered it directly into your shared document (thanks for that btw, it’s 100x easier to understand and complete the issue you may have !)
