Hi all. I have a select table in Coda that populates employee information via an automation linked to a master table. The automation adds employee information to the select table by pressing buttons that are activated if the employee meets certain criteria. I want to create an automation that automatically deletes rows from the select table IF the corresponding row in the master table is deleted. How can I do this?
First delete the coresponding row by checking the relation and then delete the source row (you are already doing it via automation).
Please share a dummy doc!
