Hey,
Insanely basic question but I just can’t get it to work.
I’m trying to create a bar chart of the sum of each column.
So the chart should just have two bars,
- FIRST bar of height 6
- SECOND bar of height 9
What am I missing?
Ian
Hey,
Ian
Hi @Ian_T
not sure you can display a summarize information from table.
I suggest the following :
switchif() function to refer to different columns SwitchIf(thisRow.Name="First",[Ian_T Problem].First.Sum(),thisRow.Name="Second",[Ian_T Problem].Second.Sum())
Please let me know if I misunderstood yoir point
thanks !
Quentin
Thats exactly what I mean @Quentin_Morel !
Thank you so much for taking the time.
It seems so strange that we can’ t do this directly in a chart. I think if Coda offered the “summarize” row, as the “Horizontal Axis” option in Chart Display.
No problem @Ian_T !
There are indeed lots of suggestion to keep on improving CODA ![]()
To extend your formula @Quentin_Morel, without creating new rows:
Is there a way to sum (First x Second).
So for you data it would 20.
(1 x 2)+ (2 x 3) + (3 x 4) = 20
Not 6x9 (obviously).
Thanks,
Ian
Quentin_Morel You are a gentleman and a scholar!
Ahah do not hesitate, I also learned from community !!
Final question…I hope.
So the two columns I’m using in SumProduct() are of types Duration, and Number.
I can’t use toNumber() to convert type, as it expects a value, not a list. So how do I convert the whole columns type in the formula?
@Ian_T
you can totally make sumproduct() with duration * number.
If you dont want to, just create a column with DurationColumn.ToNumber(), and to the sumproduct() with this new column and the number one
Anyway, the results are the same :
In your task table, is your Risk factor a number column ?
Otherwise try to add .tonumber() after the reference of this column in your somproduct
Hi @Ian_T ,
for me it’s OK. When I see the little logo after the reference in the switchif() function, il wondering :. Does your risk factor column have a number format ?
Do you have something else in your doc that is called “'RISK FACTOR”. You can see the little two rectangles logo which is diufferent than the logo with “12”. May be you are referecing something else ?
