Bart Chart & Minute Duration
Reviving the discussion from How can I change the format layout for "Duration"?:
@Al_Chen_Coda can you please see if the Coda dev team can give this feature some TLC? :grin:
Will try my best to get it prioritized!
Thank you @Al_Chen_Coda! Good luck
I don’t understand what’s the problem @jeo. Just use the Number format for the column where you multiply duration by 1440?
of course
Al's formula
Round(thisRow.Minutes.ToNumber()*1440,0)
Thank you, @Paul_Danyliuk
I feel like the problem I ran into is related…
When I create a bar chart using a column with type Duration, and configured to Hours for display, when the column is displayed, it is shown in Day units. :confused: I’m expecting that it is going to show it in Hours units, as configured.
I know this is an old topic, but I came here with this exact question :slight_smile: I have a bar chart aggregating hours and I would like it to show the total in hours, not upscale to days :slight_smile:
