Hello all,
What is the best solution for one way database sync? The sync is from one coda to many coda?
Hello all,
I’m doing it right now from 1 document to 200 documents
If it’s a 1 way sync the best way to do it is through a webhook pack. Here’s my personal favorite
And here’s a quick tutorial on how to use it and how to actually send the data over
If you’re looking for a two way sync (so that the data will write BACK to the main document) your best way, in my opinion, is the 2 way sync pack discussed here
Let me know if you have any questions!
