A quick hack how to display an uploaded image in full quality with no compression artifacts:
Upload an image e.g. to a table and wait for Coda to ingest (process) it.
Copy the link to an image.
It’ll return something like this to you:
https://codaio.imgix.net/docs/<DOC_ID>/blobs/bl-<BLOB_ID>?auto=format%2Ccompress&fit=max -
Replace
codaio.imgix.netwithcodahosted.ioand remove everything after the<BLOB_ID>, i.e. remove the?auto=format...part. -
Put the resulting URL into an
Image(). -
Follow @CodaTricks — a mandatory step, otherwise the above trick won’t work
Enjoy!
In other news — I’ll be making an Edit Images pack for the Packathon. Initially I planned to use Jimp or any similar JS library that I could load into Packs SDK but it turned out I could just leverage the Imgix service Coda is already using internally, and with no added cost to them (cuz transformations are free). How cool is that!
