[BUG] coda crashes when opening a canvas
Bonjour :slight_smile:
I don’t find where to report a bug. When opening a given canvas column, the model windows open and then close immediately resulting in a blank windows. The bug is easily reproductible :
xcriptus.public · xcritpus.public .
A friend of mine (thanks thierryvm!) give it a try and he gets the same result.
Let me know if I should post this elsewhere ! Just starting with coda :slight_smile:
Thanks
Jean-marie
Bonjour Jean-Marie,
you can post your bug in the “Suggestion Box” section. The Coda team is usually very fast in picking them up.
Bonne chance !
Thanks for reaching out @Jean-Marie_FAVRE ! @Sebastien is correct and I will move this post over to the Suggestion Box: Bugs section of the Community. If you ever come across bugs in the future, we recommend reaching out to the Coda Support team by clicking the ? in the bottom right corner of your Coda screen and submitting a bug report with this information.
Thanks @Sebastien @Shaina_Torgerson
Not sure where to find the “?” on the bottom right. I tried Learn & Help but didn’t found some useful place to go. Did I miss something ? (next time I will post it in the good place).
Hi @Jean-Marie_FAVRE :blush: !
If you click on Get Support, a small modal should open where you should find the option Send us a message :blush:
