Bug - Cross Doc not syncing all rows, some rows are blank
I’m using Cross Doc and some of the rows in the table are blank:
We had another ticket come in with a similar issue and after looking closer, I think it might be a row size issue. If the row is too big to sync, it’s skipped instead of not allowing the sync at all.
If you see this issue again, can you see if it might be a data size issue? If these are the bigger of the rows as far as the data you have included, that is a good hint as to what’s going on.
@Ben_Lee
I am still having the issue with multiple tables. It isn’t the size of the row, its a small table and some of the rows with the issue don’t have values in as many columns as others. FYI
