Button() Formula
Seems like button() is not a formally-supported function, but is there any documentation of its features, inputs, etc.?
My experiment here might be useful!
All the inputs are shown if you just type Button(), the only notable input is alertType which you can set to “Errors” to hide alert
Thanks, Rickard! This helps
Do you know why the formula isn’t supported? Or maybe someone from the Coda team could chime in?
I’m afraid not, but there’s a lot of experimental formulas, it makes sense that Coda wants to be able to try things without necessarily advertising them
Do you use the the formula in production? I would love to use it, but not if it’s really volatile
Yep! I use it all the time, to my understanding Coda is very keen to not introduce breaking changes so I’m not worried
