Buttons formula
Hello, I am stuck on a formula and was wondering if someone can tell me what I am doing wrong (coda support channel changed :frowning: )
I need to the formula to do the following, when I press a button it should automatically press all the other buttons that are equal to that row?
Can someone help me? thanks!!
hi @JEC_Aviation
You are almost there
Runactions(
thistable.Filter(xxxx.contains(thisRow.xxxx)).buttonName
cheers, Christiaan
Christiaan thanks!
Worked perfectly :smiley: :+1:
