Buttons in On-Hover Modal no longer active
Previously, hovering over a linked row would show a pop-over modal that displayed rows from the root table.
I have previously used this as a way to provide hover-access to certain context-specific buttons.
However, as of recently, the buttons (generated by formula) no longer seem to be calculating; as if the entity is not being fully loaded.
See attached screenshot for example:
Screen Shot 2023-01-03 at 7.40.59 PM
Details:
This table “Activities” (pictured) has a column with a lookup column to another table “Projects OR Departments”. Each row has a button in it “Open” that opens a linked entity in one of two separate columns (Projects or Departments), whichever is not empty (it’s a joint table, combining objects from two separate tables).
As of now, even if i open the underlying “Projects OR Departments” table before returning to this page, the buttons are not clickable.
Thank you!
Can you share the doc? Also are you using the experimental button() formula?
That’s a tough one. It’s a pretty elaborate live document with quite a bit of sensitive information. I can probably share it with you privately on a temporary basis, if you’re open to that?
In this case, it’s a simple button column. However, the action is defined formulaically
openrow(SwitchIf(thisRow.Project.IsNotBlank(),thisRow.Project,thisRow.[Internal Department].IsNotBlank(),thisRow.[Internal Department]))
Ahhh got it
No Disable criteria on your button?
Nothing in the disable field at all :man_shrugging:
Confirming, I am seeing a similar issue.
Screen Shot 2023-01-05 at 8.33.50 AM
Buttons are fully functional when directly on table, but not in On-Hover.
+1 from me. Same thing.
Interesing:
I have all my buttons enabled as seen in the screenshot below. One of my buttons is constructed via the button() formula, and the other is just a regular old button
Both are totally active
CC: @Allen_Ormond , @anon42122166 , @Billy_Jackson
Somebody share a doc with me and Ill take a look
Hopefully I’m doing this correctly.
For me, the buttons are disabled in the hover pop-up:
Capture
Getting the exact same problem, no disable criteria - super frustrating
Looks like it’s working again for me. Thanks!
Same here!
Now working :raised_hands:
