It would be great to have buttons preserve a edit row layout.
- When you expand a row to edit additional information, you can customize the layout.
- The layout that appears is the last used layout for the main table
- I have different layouts for different table views
- I also have buttons targeting table views and not the master table
- It would be great to set which layout you’d want to appear upon opening the row for editing when the button is pressed
This would be a nice feature to have in a more native way.
For now, there are a couple workarounds that get you the same result…
Definitely native would be great!
Looks like that first suggestion you posted, is what I’m looking for. Now I just need to mess around with my table.
Appreciate the help!
