Calc easter (Ostern)
How do you calculate easter in a specific year?
Is there a formula made for this?
Dear @Kristijan_Moser
As explained in this article.
The date of the Paschal Full Moon , used to determine the date of Easter what means either you have to build a table with the "The dates of the Paschal Full Moon or you build a table with the Easter dates.
Obviously there is no win having the Paschal Full Moon tables.
:thinking: Like always, I am mostly open to learn if somebody has an elegant solution
Thanks for the explanation.
I know the complex calculation because it has already been incorporated into Excel (VBA). That’s exactly what I want in Coda now.
If date = Easter then do something
I don’t want to have a table with hand-typed Easter dates. Are there ways to create formulas yourself?
Dear @Kristijan_Moser,
I understand, Coda doesn’t have this like Excel
You might consider to check if this will be an option for you:
Hi @Kristijan_Moser!
I would add a Google Calendar Pack syncing only holidays and from the current year.
Then, in another table reference the date that matches easter in the Google Calendar table.
Amazing @Saul_Garcia, the skill not to isolate yourself in a given challenge and to find a way beyond that :trophy::trophy::trophy:
