Does anybody know a way to calculate the total in a balance sheet. I mean to add or substract a number from the nube rof the row above, like in a balance sheet.
You mean calculating the running total?
Yes, I mean the running total.
An example would be very helpful here, it’s hard to know what you’re trying to do.
It is about referencing a cell in the row above.
@JHConsulting that makes sense to you as a human, but ‘the row above’ can mean lots of things in a relational database, esp with filters, sorts and views.
But I replied with a link to the solution in my answer above ![]()
and Shishir’s reply there too (he does it better by separately looking up the previous row, then using its value)
I have seen it. This answers my question. Thank you.
