Calculating the difference between rows
Hi All,
I am trying to create a simple fuel tracker, where I log me fuel $/Ltrs and total KMs. For each row I would like to calculate the difference between the current KMs and preceeding row KMs to calculate the KMs travelled as a base for other calculations
An ideas on how to achieve this simply?
hi @Andy_Farquharson2 ,
you need to find the preceding value and that is the date before the date on ‘thisRow’.
this required a correctly formated date format. below an example.
in this table the values are already sorted, sometimes you need to sort the table first on dates.
i hope it helps,
cheers, Christiaan
Thanks @Christiaan_Huizer , what is the formula that you have in step 01?
hi @Andy_Farquharson2 , see below.
cheers, Christiaan
