Calendar on mobile?
Has anyone managed to see a calendar view successfully on mobile? (IOS)
Testing here - and it seems that it only ever displays as a list,
There are many occasions where this ins’t a workable solution.
Perhaps I’m not setting something up correctly?
I’m wondering if the only way of moving forward for us is automatically mirroring one of our coda calendars on gcal. At least that will help “see” an overview of whats going on when folk are out of office.
Cheers, Brendan.
This is an important missing features on mobile!
A list is the current way a calendar table is displayed on mobile.
I’m moving this to the “Suggestion Box” so it can be seen as a request for the next calendar version.
Cool! There’s no hack to potentially display the desktop version?
A list is never going to work for a calendar :wink:
Not right now. Something we’ll put in our notes though!
at least make it sorted accordingly
If you change from Calendar view to Table view and sort the table there, doesn’t that sort carry over to the mobile list?
I believe this should work, but let me know if it doesn’t.
yes, it does. but table view would be both platforms - mobile and web. So, how to use calendar view for web?
as a workaround is to create separate section with calendar view, but it is already awkward
Sorry, after you set the sort for the table layout, then you should be able to change it back to the calendar view for the web.
Does make sense! thank you!
As far as I can tell, no - it doesn’t use the table sorting. I have tried adding sorting on the start-date column, both ascending and descending, and the mobile view stays sorted the same.
If it was sorted the right way, then the list would have “some” merit. Now it is just about useless to be honest. The way I see this, this is not a feature request or an improvement. Sorting the list the wrong way is a bug.
At least the timeline view seems to work so that is my fallback for now. For mobile users I have added a separate sub-page for them to view the timeline in.
Implementing a calendar view is really important I believe, so I am hoping that it is on the shortlist of new features to implement soon :).
I am by the way on Android - for the record. Have no idea if iOS users have the same issue.
It’s July of 2023 and the mobile view of a calendar still sorts the events backwards. Very frustrating.
I’ve tried sorting the original table by ascending date. I’ve tried sorting the view by ascending date. But when it renders for mobile, it ignores all that and sorts by descending date, so the most distant event is at top. What is the workaround to publish a calendar for mobile users?
Note: it doesn’t matter if you use the original table or a view of the table, when viewed as a calendar, the sort is backwards on mobile.
Has anyone figured out a workaround for fixing this sorting issue? On mobile my calendar views are still sorting backwards.
@Ben_Lee It’s been 4 years – how is it that we STILL don’t have a better calendar view on mobile? The reverse-sorted list is not even comparable to the full calendar being displayed and it never should have been set up this way. Why is it taking so long to fix such a massively broken feature?
Any updates on this being a feature?
Still no updates @Ben_Lee ??
I jump in here (:slight_smile: Would be very very appreciated here to have a calendar view on mobile (or at very least control over the sort mechanism!). Is there any priority on this 4 years later?
And minimal improvements on the web layout as well (such as defining which columns are shown). The default “display” column is not always the one (and rarely the only one) that should be displayed…
