Is there a way to disable copy table functions from my doc. Since my tables have confidential data and even if locked and hidden to some user they can still copy those tables and paste to their own documents allowing them to remove the filter and see the inside data from the copied table.
There isn’t currently a way to do this within a doc.
One option might be to use a separate doc and use Cross-doc to bring over only the information you want to display. You can create a view of a table and hide columns and rows that you don’t want to show, then when Cross-doc syncs that table, it will only sync what is displaying in the table or view and will not allow access to other columns or rows that are hidden.
Yup. This is my solution too. Also copying cross-docs needs API tokens so I think this is good for now. Thanks!
