Can we use Section header emoticons/icons in text
There are far more emoticons/icons in the Section header than are available through the standards exposed with unicode.
Is it possible to somehow access these in text in a Section?
It’s probably not quite what you are after(?), but you can right-click the icon, copy the image and then paste it in your doc -
The problem there is that you can’t use the image everywhere where you use text (row entries etc)
I also find myself wanting to use the large set of iconography, but it’s not easily available.
The solution from @anon86103599 is one option and another is grabbing the link of the image in the same way mentioned and then using the Image() formula.
Sadly, same issue - At the moment image rendering doesn’t work for values of a display column - which breaks this.
