Cannot reference to other users
Hi,
When I type @, I cannot reference to other users. The only user that is found is me.
Weird, because I do have tables with columns of the ‘People’ type where other users are referenced.
Is this a bug or am I doing something wrong?
I like to populate a Select control with some users, so that I can dynamically filter a view.
Thanks for your help.
Best, Koen
Dear @anon7107569,
Are you sure you shared the doc with the intended users?
Only then you will be able to reference them :slight_smile:
Hi @Jean_Pierre_Traets,
Yes, the document is shared with the others.
Yet I cannot reference them when I type @
Is there maybe any other way to populate a Select control with all users?
Best, Koen
Hi @anon7107569,
I just created a small test doc, and it works fine.
Did you try it an another doc to see if it works, with at least 2 users?
Another option I would try is to make a copy of your current doc and to see if you will be lucky
:slight_smile:
Otherwise write to support@coda.io, I am sure they will be able to see the status of your file
Same behavior in a new doc… I’ll write to support@coda.io
Thanks
FYI, this issue is resolved.
Although the document was shared with others on our Gsuite, referencing to other users was not possible until they had opened the document once.
