Can't Copy Error Messages?
Is there not a way to copy error messages from formulas? When I am troubleshooting a formula and get an error, I am unable to copy the text of the error message so I can paste elsewhere for answers. The error text is unselectable/uncopyable. I gotta be missing something easy-dumb, right?
Hi @Monroe_Claycomb,
I just did a little testing and figured out you can not copy the error-text in the simple formula-editor. But you can if you use the expanded formula-editor.
(Not working) Simple Formula-Editor:
(Working) Expanded Formula-Editor:
I hope that solved your question.
Feel free to ask if anything is unclear.
Sincerely
Jannis
I have this issue all the time. :sweat_smile:
Ideally, Coda should have a “copy” icon to make it easy to copy an error message.
Or even better, it should try to provide suggestions on fix with AI. (similar to Grammarly or QuillBot)
