Can't create Jira issues of type Epic
I can’t create a Jira issue of type “Epic”. I get an error each time. Changing the issue type to Task or Story works fine. Any ideas?
I’d like to create Epics from Coda, too :confused:
Still generates an error…
Dear @Gannon_Hall1,
Better now then never, this might be what you have been looking for: :thinking:
This might be an issue with Jira’s different types of projects. I’m not sure if our pack can use epics if it’s a “Classic” project. I think the “Next-gen” projects should work for an epic.
I’ll try to test this out and see if this is the issue.
Support for “Epics” broke with the new version of Jira. The version that looks like this.
I checked with engineering and it’s a known issue and currently we don’t have a solution. It’s in our notes and we’ll check it out and see if we can get it up and running.
Same thing. This would be great!
Any news on this bug? I’m doing a manual workaround still. Solid support for the Jira object model t (Epics, etc,) would be awesome.
FYI that the workaround for this is to use Zapier as it supports the creation of Epics for “classic” projects in Jira.
