Hey Folks, we are using Coda as an HR ticketing system. As such, we have sub-docs where other departments that have overlap on certain tickets (finance, IT) can view those subsets of issues.
In the ticket, there is a canvas column where we add details/email notes, etc. Essentially, we ran into the issue where editing canvas columns is not supported by Coda.
Has anyone discovered a workaround we could use?
Astha
there are only 2 workarounds i know of..
#1. use text cells instead if canvas cells - ie give up all the extra features of the canvas and allow only multi-line texts instead.
#2. use hidden formulas to extract the HTML from the canvas cell and share that via cross-doc. then use a pack to render the HTML on the other side. but that prevents 2 way editing.
right now we need to make a hard choice.
only cross-dox plain text columns and have users paste in URLs for attatchments.
or use canvas columns amd avoid cross-doc sharing of data (a single doc with separate pages for each department).
hoping this limitation is rectified soon.
Thank you for sharing the workarounds you have used! Really hope Coda fixes this soon.
Back to ask if this is on the roadmap…its an ongoing pain-point in creating central docs that can be shared with different groups.
