Hi there,
I´ve changed the layout of a card as shown below, so that the red section appears on the right of the yellow section, i ve named this as layout2 and have selected it as my default layout
However the card doesnt appear like that. The red section appears below the yellow one as shown below
Thanks a lot in advance
@Alvaro_Lacalle
The Layout is different from card view. Card view goes from Columns order.
Hope this helps!
Cheers!
Mel
thnaks for taking the time to answer my question Mel, but here it is affecting the view this for example is layout 2
and this the default layout
but if layout doesnt affect the view what does it do? and where can i access column order, im checking the table options and cant find it
thanks a lot
here i can change the order of the columns, one below the other but not one nex to the other
im sorry for replygin so many times but i cant attach more than one image per post
As @Melanie_Teh said, the Layout view applies to Views of tables, not to Card Views
P
@Alvaro_Lacalle
No worries about the 3 posts
I’ve had to do similar haha
Thanks @Piet_Strydom and just to expand from his post - the card view is in red circle. And the columns order is in yellow circle.
Your image posts showed you were still in Layout detail view.
Hope this clears things up and if not, please don’t hesistate to bring up anything you’re still stuck on
Cheers!
Mel
