Choices of relational select lists, based on other columns
Hello everybody,
I’m trying to display messages in a column based on a select list choice of the column in front.
→ But the choices inside the select list, need to be filtered by the values of the cells infront of the select list.
I did make a video to explain it better:
Here’s the Doc:
Hi @Isebar_DE,
I’ve improved your data structure a bit and did the changes you described.
Please review your document and let me know if this is how you envisioned it.
Best regards
Jannis
@Jannis so i think some of the improvement makes a lot of sense, but i still have to wrap my head around it.
But the filtering isn’t working correct yet:
@Jannis that is totaly correct:
Hi @Isebar_DE,
you are right. I forgot to add a second filter, sorry.
Everything should work as expected now.
Please check your doc and let me know if anything works as you want it to work.
Best regards
Jannis
@Jannis this is it. It’s actually more than i asked for. You are my weekend hero!
Thank so much, @Isebar_DE!
I’m glad everything works as you imagined.
I wish you a nice rest of the weekend.
Jannis
