Chrome extension issues
is the coda chrome extension going to be fixed?
Thanks for reaching out, @AJM . After checking in with the team, it looks like our resources are being allocated elsewhere at the moment and there are currently no plans to work on the browser extension. Thanks in advance for your understanding.
Hi Shaina,
The person who runs Coda’s twitter account says the chrome extension works. Can you clarify?
I use it on a near daily basis, and have had no problems.
I also do not see the error message when I look at the extension in Play Store. Do you still see it?
P
I’m not seeing it now, no.
I stopped using it after Shaina’s comment in August and spent quite a bit of time finding an alternative. I have to admit it’s frustrating to be told that coda won’t be updating this (essentially phasing it out), only to later find out it was updated and no one mentioned it!!
The message was from Chrome though, and it says may.
Coda said “no new work”, which doesn’t mean “essentially phasing it out”.
Chrome extensions that don’t have their code updated to the v3 manifest are being removed from browsers. I obviously looked into it before asking whether coda intended to update the extension.
