Hi
I am using Charts a lot. My problem with them, compared with conventional charts made with Google Spreadsheets or Excel, is that Charts are not adjustable. For instance, I cannot expand a bar chart vertically in order to make space for all of the entries
For instance, I cannot change vertical dimension of chart nor any label of it
Do you Codans plan to enrich chart displays?
